Version: 8.1
system.security.getUserRoles
Fetches the roles for a user from the Gateway. This may not be the currently logged in user. Requires the password for that user. If the authentication profile name is omitted, then the current project's default authentication profile is used.
Syntax - Vision​
system.security.getUserRoles(username, password, [authProfile], [timeout])
StringusernameThe username to fetch roles for
StringpasswordThe password for the user
StringauthProfileThe name of the authentication profile to run against. Optional. Leaving this out will use the project's default profile. [optional]
IntegertimeoutTimeout for client-to-gateway communication. Default is 60,000ms. [optional]
Tuple - A list of the roles that this user has, if the user authenticates successfully. Otherwise, returns None.
Vision Client
Syntax - Gateway and Perspective​
system.security.getUserRoles(username, password, [authProfile])
StringusernameThe username to fetch roles for.
StringpasswordThe password for the user.
StringauthProfileThe name of the authentication profile to run against. Leaving this out will use the project's default profile. [optional]
Gateway, Perspective Session
Example #1
# Fetch the roles for a given user, and check to see if the role "Admin" is in them.
reqRole = "Admin"
username = "Billy"
password= "Secret"
roles = system.security.getUserRoles(username, password)
if reqRole in roles:
# do something requiring "Admin" role.
