system.security.validateUser
Tests credentials (username and password) against an authentication profile (User Source). Returns a boolean based upon whether or not the authentication profile accepts the credentials. If the User Source name is omitted, then the current project's default authentication profile is used.
Syntax (Client)​
system.security.validateUser(username, password, [authProfile], [timeout])
| String | username | The username to validate. |
| String | password | The password for the user. |
| String | authProfile | The name of the authentication profile (User Source) to run against. Leaving this out will use the project's default profile. [optional] |
| Integer | timeout | Timeout for Client-to-Gateway communication. Default is 60,000ms. [optional] |
Boolean - False if the user failed to authenticate; True if the username/password was a valid combination.
Vision Client
Syntax (Gateway)​
system.security.validateUser(username, password, [authProfile])
| String | authProfile | The name of the authentication profile (User Source) to run against. Optional. Leaving this out will use the project's default profile. [optional] |
Gateway, Perspective Session
Code Example​
# This would require the current user to enter their password again before proceeding.
passMessage = "Confirm Password"
passTitle = "Password Dialog Box"
currentUser = system.vision.getUsername()
password = system.vision.showPasswordInput(passMessage, passTitle)
valid = system.security.validateUser(currentUser, password)
# Decide what to do based off result:
if valid:
print("Validated!")
else:
system.vision.showError("Incorrect Password", "Wrong Password")
