system.report.executeReport
Immediately executes an existing report and returns a byte[] of the output.
note
system.report.executeReport(path, project, [parameters], fileType)
StringpathThe path to the existing report.
StringprojectThe name of the project where the report is located. Optional in Client scope.
PyDictionaryparametersA optional dictionary of parameter overrides, in the form name:value.
StringfileTypeThe file type the resulting byte array should represent. Defaults to "pdf". Not case-sensitive.
byte[] - A byte array of the resulting report.
Throws​
IllegalArgumentException - Thrown when any of the following occurs: If the file type is not recognized, path does not exist, project does not exist.
All
Values for the fileType Parameter​
Acceptable values are:
  • pdf
  • html
  • csv
  • rtf
  • jpeg
  • png
  • xml
Code Snippet
# Executes the report, overriding two parameters
overrides = {"myStringParam":"Hello world", "myIntParam":3}
bytesArray = system.report.executeReport(path="My Path", project="MyProject", parameters=overrides, fileType="pdf")
