Version: 8.1
system.report.executeReport
Immediately executes an existing report and returns a List[Byte] of the output. Throws an IllegalArgumentException when any of the following occurs: If the file type is not recognized, path does not exist, project does not exist.
note
system.report.executeReport(path, project, [parameters], fileType)
StringpathThe path to the existing report.
StringprojectThe name of the project where the report is located. Optional in client scope.
Dictionary[String, Integer]parametersA dictionary of parameter overrides, in the form name:value. [optional]
StringfileTypeThe file type the resulting byte array should represent. Defaults to "pdf". Not case-sensitive
List[Byte] - A byte array of the resulting report.
Values for the fileType Parameter​
Acceptable values are:
  • pdf
  • html
  • csv
  • rtf
  • jpeg
  • png
  • xml
  • xls
  • xlsx
xls and xlsx Formats
The xls and xlsx format options may return less than pixel perfect results. This is due to how many spreadsheet programs interpret the resulting file. As a result, the pdf format is recommended in most cases.
Code Example​
Code Snippet - Executing Report
# Executes the report, overriding two parameters.
overrides = {"myStringParam":"Hello world", "myIntParam":3}
bytesArray = system.report.executeReport(path="My Path", project="MyProject", parameters=overrides, fileType="pdf")
