system.report.executeReport
Descriptionβ
Immediately executes an existing report and returns a List[Byte] of the output. Throws an IllegalArgumentException when any of the following occurs: If the file type is not recognized, path does not exist, project does not exist.
Syntaxβ
system.report.executeReport(path, project, [parameters], fileType)
Parametersβ
| String | path | The path to the existing report. |
| String | project | The name of the project where the report is located. Optional in client scope. |
| Dictionary[String, Integer] | parameters | A dictionary of parameter overrides, in the form name:value. [optional] |
| String | fileType | The file type the resulting byte array should represent. Defaults to "pdf". Not case-sensitive |
Returnsβ
List[Byte] - A byte array of the resulting report.
Scopeβ
Values for the fileType Parameterβ
Acceptable values are:
- html
- csv
- rtf
- jpeg
- png
- xml
- xls
- xlsx
The xls and xlsx format options may return less than pixel perfect results. This is due to how many spreadsheet programs interpret the resulting file. As a result, the pdf format is recommended in most cases.
Code Exampleβ
# Executes the report, overriding two parameters.
overrides = {"myStringParam":"Hello world", "myIntParam":3}
bytesArray = system.report.executeReport(path="My Path", project="MyProject", parameters=overrides, fileType="pdf")
