system.report.getReportNamesAsDataset
Descriptionβ
Gets a data of all reports for a project. Throws an IllegalArgumentException when any of the following occurs: If the project name is omitted in the Gateway scope, project does not exist.
Syntaxβ
note
system.report.getReportNamesAsDataset([ project], [includeReportName])
Parametersβ
| String | project | The name of the project where the reports are located. Optional in client scope. |
| Boolean | includeReportName | New in 8.1.5 When set to False, the end of Path does not include the report name. Default is True. [optional] |
Returnsβ
Dataset - A dataset of report paths and names for the project. Returns an empty dataset if the project has no reports.
Scopeβ
Code Examplesβ
Code Snippet
# Gets a dataset of reports for the current project and displays
# them in a Tree View component.
event.source.parent.getComponent('Tree View').data = system.report.getReportNamesAsDataset()
