system.report.executeAndDistribute
Executes and distributes a report. Similar to scheduling a report to execute, except a schedule is not required to utilize this function. This is a great way to distribute the report on demand from a client.
caution
The function system.report.executeAndDistribute() does not run on its own thread and can get blocked. For example, if a printer is backed up and it takes a while to finish the request made by this function, the script will block the execution of other things on that thread until it finishes. Be sure to keep this in mind when using it in a script.
note
system.report.executeAndDistribute(path, project, [parameters], action, [actionSettings])
StringpathThe path to the existing report.
StringprojectThe name of the project where the report is located. Optional in Client scope.
PyDictionaryparametersA optional dictionary of parameter overrides, in the form name:value.
StringactionThe name of the distribution action to use. The action parameter supports the following keys as strings:
  • email
  • print
  • save
  • ftp
  • PyDictionaryactionSettingsAn optional dictionary of settings particular to the action. Missing values will use the default value for that action.
    None
    Throws​
    IllegalArgumentException - Thrown when any of the following occurs: If the file type is not recognized, path does not exist, project does not exist, or a key is not valid.
    All
    Values for actionSettings​
    The action settings parameter supports an optional dictionary of settings particular to the action. Missing values will use the default value for that action.
    • email
      • Setting Keys: "smtpServerName", "from", "subject", "body", "attachmentName", "retries", "fileType", "to", "cc", "bcc", "replyTo", "useRoles", "roles", "userSource", "replyToRoles", "replyToUserSource".
      note
      To, cc, bcc, and replyTo must be Python lists. If useRoles is True, to, cc and bcc will be ignored and all email addresses for all users matching roles in userSource (which defaults to the project's current user source) will be in the to field. Similarly, all users matching the replyToRoles in replyToUserSource will be in the reply to field of the email. If useRoles is true but no roles are listed, all user email addresses in userSource will be in the to field. If omitted, fileType defaults to pdf.
      New in 7.9.8
      The email action now has the ability to add emails to the reply to field of the email. The replyTo, replyToRoles, and replyToUserSource keys have been added to the possible dictionary options.
    • print
      • Setting Keys: "primaryPrinterName", "backupPrinterName", "copies", "printBothSides", "collate", "useRaster", "rasterDPI", "useAutoLandscape", "pageOrientation".
      note
      primaryPrinterName defaults to the default printer. backupPrinterName defaults to "none", but can also have the special value of "default". printBothSides, collate, and useRaster are booleans which default to false. rasterDPI is only used if useRaster is true. useAutoLandscape defaults to true. If useAutoLandscape is false, pageOrientation, which can have values of "portrait" or "landscape" (default is "portrait"), is used.
    • save
      • Setting Keys: "path", "fileName" and "format".
      note
      Since the script is sent to the gateway for execution, path and fileName must be relative to the Gateway.
    • ftp
      • Setting Keys: "server", "port", "username", "password", "useSSL", "path", "fileName", and "format".
      note
      Server and fileName are required. If omitted, fileType defaults to pdf, port defaults to 21, and useSSL defaults to false.
    Values for filetype and format​
    The following is a list of values for the actionSettings filetype and format keys.
    • pdf
    • html
    • csv
    • rtf
    • jpeg
    • png
    • xml
    Code Snippet 1
    # Executes and distributes the report to an email address.
    system.report.executeAndDistribute(path="My Report Path", project="My Project", action= "email",
    actionSettings = {"to":["plantmanager@myplant.com"], "smtpServerName":"myplantMailServer", "from":"reporting@myplant.com", "subject":"Production Report"})
    Code Snippet 2
    # Executes and distributes the report to all users in the default user source who are Supervisors or Managers.
    actionSettings = {"useRoles":True, "roles":["Supervisor", "Manager"], "smtpServerName":"myplantMailServer", "from":"reporting@myplant.com", "subject":"Production Report"})
    Code Snippet 3
    # Executes and distributes the report to an ftp server with parameter values passed into the report
    reportParameters = {"startDate":system.date.addHours(system.date.now(), -12), "endDate":system.date.now()}
    settings = {"server":"10.20.1.80", "port":22, "username":"Ignition", "password":"Secret", "useSSL": False, "path":"C:\\FTP", "fileName":"Ignition Report", "format":"pdf"}
    system.report.executeAndDistribute(path="My Report Path", project="My Project", parameters=reportParameters, action= "ftp", actionSettings = settings)
    Code Snippet 4
    # Executes and distributes the report to save a PDF
    settings = {"path":"C:\\Ignition Reports", "fileName":"Report.pdf", "format":"pdf"}
    system.report.executeAndDistribute(path="My Report Path", project="My Project", action="save", actionSettings=settings)
