system.nav.getCurrentWindow
Returns the path of the current "main screen" window, which is defined as the maximized window. With the Typical Navigation Strategy, there is only ever one maximized window at a time.
system.nav.getCurrentWindow()
None
String - The path of the current "main screen" window - the maximized window.
Client
Code Snippet
# This code could run in a global timer script.
# After a 5-minute timeout, navigate back to the home screen
if system.util.getInactivitySeconds()>300 and system.nav.getCurrentWindow()!="Home":
system.nav.swapTo("Home")
