system.nav.desktop
Allows for invoking system.nav functions on a specific desktop.
See the Multi-Monitor Clients page for more details.
system.nav.desktop(handle)
StringhandleThe handle for the desktop to use. The screen index casted as a string may be used instead of the handle. If omitted, this will default to the Primary Desktop. Alternatively, the handle "primary" can be used to refer to the Primary Desktop.
INavUtilities - A copy of system.nav that will atler the desktop named by the given handle.
Client
Code Snippet
# The following example will close a window at path "Main Windows/Overview" in the Primary Desktop,
# regardless of where the script originates from.
system.nav.desktop().closeWindow("Main Windows/Overview")
Code Snippet
# Attempts to swap to a window at path "Main Windows/Main Window" on a specific Desktop. This example assumes a desktop with the handle "2nd Desktop" is already open.
system.nav.desktop("2nd Desktop").swapTo("Main Windows/Main Window")
