system.dnp3.freezeAnalogsAtTime
Issues a freeze command on the given analog outputs at the given time for the specified duration.
Permission Type: DNP3 Management
system.dnp3.freezeAnalogsAtTime(deviceName, absoluteTime, intervalTime, indexes)
StringdeviceNameThe name of the DNP3 device driver.
IntegerabsoluteTimeThe absolute time at which to freeze, in millis.
IntegerintervalTimeThe interval at which to periodically freeze, in millis.
ListindexesA list of specific indexes on which to issue the freeze command. An empty list will freeze all analogs.
Nothing
All
Example #1
# This example shows a request to freeze analog inputs at indexes 2 and 4,
# 5 minutes from the current time, with no interval.
from time import *
fiveMikes = (60 * 1000 * 5) + int(time() * 1000) #ms
system.dnp3.freezeAnalogsAtTime("Dnp3", fiveMikes, 0, [2, 4])
