system.dnp3.selectOperateBinary
Issues a Select-And-Operate command for digital control operations at binary output points (CROB).
Permission Type: DNP3 Management
system.dnp3.selectOperateBinary(deviceName, indexes, opType, tcCode, count, onTime, offTime)
StringdeviceNameThe name of the DNP3 device driver.
ListindexesA list of indexes of the objects to be modified in the outstation.
IntegeropTypeThe type of operation. 0=NUL, 1=PULSE_ON, 2=PULSE_OFF, 3=LATCH_ON, 4=LATCH_OFF
IntegertcCodeThe Trip-Close code, used in conjunction with the opType. 0=NUL, 1=CLOSE, 2=TRIP
IntegercountThe number of times the outstation shall execute the operation.
IntegeronTimeThe duration that the output drive remains active, in millis.
IntegeroffTimeThe duration that the output drive remains non-active, in millis.
The DNP3 status code of the response, as an integer.
All
Example #1
# This example shows latching on 3 binary output points with the Select-And-Operate command.
latch = system.dnp3.LATCH_ON
system.dnp3.selectOperateBinary("Dnp3", [0, 1, 2], latch)
Example #2
# This example shows setting a binary output point at index 3 to pulse at 5 second intervals
# with the Select-And-Operate command.
pulse = system.dnp3.PULSE_ON
trip = system.dnp3.TRIP
system.dnp3.selectOperateBinary("Dnp3", [3], pulse, trip, count=2, onTime=5000, offTime=5000)
