Cylindrical Tank
Component Palette Icon
A component that looks like a 3D cylindrical tank, with some liquid inside. The liquid rises and falls as the Value property changes.
Properties​
NameDescriptionProperty TypeScriptingCategory
Anti AliasDraw with antialias on? Makes text smoother.boolean.antiAliasAppearance
Background ColorThe background color of the component.Color.backgroundAppearance
BorderThe border surrounding this component. NOTE that the border is unaffected by rotation.Border.borderCommon
CapacityTotal capacity of tank.double.capacityData
CursorThe mouse cursor to use when hovering over this component.int.cursorCodeCommon
Data QualityThe data quality code for any tag bindings on this component.int.dataQualityData
FontFont of text on this component.Font.fontAppearance
Font ColorThe color of the value and/or percentage labels.Color.fontColorAppearance
Foreground ColorThe foreground color of the component.Color.foregroundAppearance
Liquid ColorColor of the filled tank section.Color.liquidColorAppearance
Mouseover TextThe text that is displayed in the tooltip which pops up on mouseover of this component.String.toolTipTextCommon
NameThe name of this component.String.nameCommon
Percent FormatFormat string used for the percentage.String.percentFormatAppearance
RotationThe angle of rotation in degrees.int.rotationAppearance
Show PercentageShow percentage of tank filled?boolean.showPercentAppearance
Show ValueShow numeric value, capacity, and units?boolean.showValueAppearance
StylesContains the component's styles.Dataset.stylesAppearance
Tank ColorColor of the non-filled tank section.Color.tankColorAppearance
UnitsUnits of measure for tank contents.String.unitsAppearance
ValueNumeric value of tank's level.double.valueData
Value FormatFormat string used for the value.String.valueFormatAppearance
VisibleIf disabled, the component will be hidden.boolean.visibleCommon
Scripting​
Scripting Functions​
This component does not have scripting functions associated with it.
Extension Functions​
Event Handlers​
Customizers​
Examples​
Property NameValue
Value800
Show ValueTrue
Show PercentageFalse
