system.secsgem.getToolProgramDataset
Returns a Dataset containing information about all stored process programs.
system.secsgem.getToolProgramDataset()
None
Dataset - A Dataset containing information about all stored process programs. Includes the following columns in order: ppid, editDate, bodyFormat.
  • ppid - The name (PPID) of the program.
  • editDate - The last known date the program was saved.
  • bodyFormat - The format of the program. Uses notation matching SECS item definitions: "A" for ASCII, "B" for binary, etc.
Gateway, Designer, Client
Code Snippet
# Retrieve information about all programs.
results = system.secsgem.getToolProgramDataset()
# Convert the Dataset to a PyDataset, since they are easier to iterate over.
pyResults = system.dataset.toPyDataSet(results)
for program in pyResults:
# Print out details on each program.
print "Program %s was last modified on %s" % (program[0], program[1])
