system.net.httpDelete
Performs an HTTP DELETE to the given URL.
Keep in mind that JRE proxy settings will influence how these functions conduct their network activities. When using a non-bundled JRE, this is typically set via the Java Control Panel.
tip
system.net.httpDelete(url, [contentType], [connectTimeout], [readTimeout], [username], [password], [headerValues], [bypassCertValidation])
StringurlThe URL to send the request to.
StringcontentType[Optional] The MIME type used in the HTTP 'Content-type' header.
IntconnectTimeout[Optional] The timeout for connecting to the URL in milliseconds. Default is 10,000
IntreadTimeout[Optional] The read timeout for the operation in milliseconds. Default is 60,000.
Stringusername[Optional] If specified, the call will attempt to authenticate with basic HTTP authentication.
Stringpassword[Optional] The password used for basic HTTP authentication, if the username parameter is also present.
PyDictionaryheaderValues[Optional] A dictionary of name/value pairs that will be set in the HTTP header.
BooleanbypassCertValidation[Optional] If the target address in an HTTPS address, and this parameter is TRUE, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates.
Object - The content returned for the DELETE operation.
All
Code Example​
Code Snippet
# This example attempts to perform a DELETE operation
URL = "http://myURL/folder.resource"
system.net.httpDelete(URL)
