system.net.httpDelete
Descriptionβ
Performs an HTTP DELETE to the given URL.
Keep in mind that JRE proxy settings will influence how these functions conduct their network activities.
Syntaxβ
tip
system.net.httpDelete(url, [contentType], [connectTimeout], [readTimeout], [username], [password], [headerValues], [bypassCertValidation])
Parametersβ
| String | url | The URL to send the request to. |
| String | contentType | [Optional] The MIME type used in the HTTP 'Content-type' header. |
| Int | connectTimeout | [Optional] The timeout for connecting to the URL in milliseconds. Default is 10,000 |
| Int | readTimeout | [Optional] The read timeout for the operation in milliseconds. Default is 60,000. |
| String | username | [Optional] If specified, the call will attempt to authenticate with basic HTTP authentication. |
| String | password | [Optional] The password used for basic HTTP authentication, if the username parameter is also present. |
| PyDictionary | headerValues | [Optional] A dictionary of name/value pairs that will be set in the HTTP header. |
| Boolean | bypassCertValidation | [Optional] If the target address in an HTTPS address, and this parameter is TRUE, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates. |
Returnsβ
String - The content returned for the DELETE operation.
Scopeβ
Code Exampleβ
Code Snippet
# This example attempts to perform a DELETE operation
URL = "http://myURL/folder.resource"
system.net.httpDelete(URL)
