system.net.sendEmail
Descriptionβ
Sends an email through the given SMTP server. Note that this email is relayed first through the Gateway; the Client host machine doesn't need network access to the SMTP server.
Note that you can use this function to send emails as text messages. Most phone service providers offer a domain that can be used to convert emails into text messages. For example: 1234567890@phone.domain.com. Contact your cell carrier for details.
.ics, .ifb, .otf, and .wav. Additional or modified mappings may be specified in \webserver\webdefault.xml:
<!-- Add <mime-mapping> blocks like the one below or modify default mappings -->
<!-- Map the file extension 'pwn' to the specified mime-type: -->
<mime-mapping>
<extension>pwn</extension>
<mime-type>application/vnd.3m.post-it-notes</mime-type>
</mime-mapping>
Syntaxβ
system.net.sendEmail(smtp, fromAddr, [subject], [body], [html], to, [attachmentNames], [attachmentData], [timeout], [username], [password], [priority], [smtpProfile], [cc], [bcc], [retries], [replyTo])
Parametersβ
| String | smtp | The address of an SMTP server to send the email through, like mail.example.com. A port can be specified, like mail.example.com:25. STARTTLS can also be forced, like mail.example.com:587:tls. |
| String | fromAddr | An email address to have the email come from. |
| String | subject | The subject line for the email. [optional] |
| String | body | The body text of the email. [optional] |
| Boolean | html | A flag indicating whether or not to send the email as an HTML email. Will auto-detect if omitted. [optional] |
| List[String] | to | A list of email addresses to send to. New in 8.1.48 This parameter becomes optional if either the cc or bcc parameter is specified. |
| List[String] | attachmentNames | A list of attachment names. Attachment names must have the correct extension for the file type or an error will occur. [optional] |
| List[Byte] | attachmentData | A list of attachment data, in binary format. [optional] |
| Integer | timeout | A timeout for the email, specified in milliseconds. Defaults to 300,000 milliseconds (5 minutes). [optional] |
| String | username | If specified, will be used to authenticate with the SMTP host. [optional] |
| String | password | If specified, will be used to authenticate with the SMTP host. [optional] |
| String | priority | Priority for the message, from "1" to "5", with "1" being highest priority. Defaults to "3" (normal) priority. [optional] |
| String | smtpProfile | If specified, the named SMTP profile defined in the Gateway will be used. If this keyword is present, the smtp, username, and password keywords will be ignored. [optional] |
| List[String] | cc | A list of email addresses to carbon copy. Only available if an smtpProfile is used. [optional] |
| List[String] | bcc | A list of email addresses to blind carbon copy. Only available if an smtpProfile is used. [optional] |
| Integer | retries | The number of additional times to retry sending on failure. Defaults to 0. Only available if an smtpProfile is used. [optional] |
| List[String] | replyTo | An optional list of addresses to have the recipients reply to. If omitted, this defaults to the from address. [optional] |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
# This code would send a simple plain-text email to a single recipient, with no attachments
body = "Hello, this is an email."
recipients = ["bobsmith@mycompany.com"]
system.net.sendEmail("mail.mycompany.com",
"myemail@mycompany.com", "Here is the email!", body, 0, recipients)
# This code would send an HTML-formatted email to multiple recipients (including
# cellphones) with no attachments
body = "<HTML><BODY><H1>This is a big header</H1>"
body += "And this text is <font color='red'>red</font></BODY></HTML>"
recipients = ["bobsmith@mycompany.com", "1235558383@vtext.com", "sally@acme.org", "1235557272@vtext.com"]
myuser = "mycompany"
mypass = "1234"
system.net.sendEmail(smtp="mail.mycompany.com", fromAddr="myemail@mycompany.com",
subject="Here is the email!", body=body, html=1, to=recipients, username=myuser, password=mypass)
# This code ask the user for an attachment file and attaches the file.
filePath = system.file.openFile()
if filePath != None:
# This gets the filename without the C:\folder stuff
fileName = filePath.split("\\")[-1]
fileData = system.file.readFileAsBytes(filePath)
smtp = "mail.mycompany.com"
sender = "myemail@mycompany.com"
subject = "Here is the file you requested"
system.net.sendEmail(smtp, sender, subject, body, 0, recipients, [fileName], [fileData])
# This code would send an HTML-formatted email to multiple recipients, including a cc, with no attachments,
# using an smtp server defined in the Gateway
cc_recipients = ["annejones@mycompany.com"]
smtp_server = "mySmtpServer"
system.net.sendEmail(smtpProfile=smtp_server, fromAddr="myemail@mycompany.com", subject="Here is the email!", body=body, html=1, to=recipients, cc=cc_recipients)
