system.net.getExternalIpAddress
Descriptionβ
Returns the Client's IP address, as it is detected by the Gateway. This means that this call will communicate with the Gateway, and the Gateway will tell the Client what IP address its incoming traffic is coming from. If you have a client behind a Network Address Translation (NAT) router, then this address will be the Wide Area Network (WAN) address of the router instead of the Local Area Network (LAN) address of the Client, which is what you'd get with system.net.getIpAddress.
Syntaxβ
system.net.getExternalIpAddress()
Parametersβ
Nothing
Returnsβ
String - A text representation of the client's IP address, as detected by the Gateway
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
# Put this script on a navigation button to restrict users from opening a specific page.
ip = system.net.getExternalIpAddress()
# check if this matches the CEO's IP address
if ip == "66.102.7.104":
system.nav.swapTo("CEO Dashboard")
else:
system.nav.swapTo("Manager Dashboard")
