system.net.openURL
Descriptionβ
Opens the given URL or URI scheme outside of the currently running Client in whatever application the host operating system deems appropriate. For example, the URL:
"http://www.google.com"
will open in the default web browser, whereas this one:
"file://C:/Report.pdf"
will likely open in Adobe Acrobat. The Windows network-share style path like:
"\\Fileserver\resources\machine_manual.pdf"
will work as well (in Windows).
caution
Be careful not to use this function in a full-screen client, as launching an external program will break your full-screen exclusive mode.
Syntaxβ
system.net.openURL(url [, useApplet])
Parametersβ
| String | url | The URL to open in a web browser. |
| Boolean | useApplet | If set to true (1), and the client is running as an Applet, then the browser instance that launched the applet will be used to open the URL. [optional] |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code would open a web page
system.net.openURL("http://www.google.com")
Example #2
# This code would open a PDF document located at C: on the client computer
# Note the double backslashes are needed because backslash is the escape character
# for Python
system.net.openURL("file://C:\\myPDF.pdf")
Example #3
# This code would open a PDF document from a Windows-based file server
# for Python
system.net.openURL("\\\\MyServer\\MyDocs\\document.pdf")
