system.net.httpPut
Descriptionβ
Performs an HTTP PUT to the given URL. Encodes the given dictionary of parameters using "applications/x-www-form-urlencoded" format.
Keep in mind that JRE proxy settings will influence how these functions conduct their network activities.
Syntaxβ
tip
system.net.httpPut(url, [contentType], putData, [connectTimeout], [readTimeout], [username], [password], [headerValues], [bypassCertValidation])
Parametersβ
| String | url | The URL to put to. |
| String | contentType | The MIME type used in the HTTP 'Content-type' header. [optional] |
| String | putData | The raw data to put via HTTP. |
| Int | connectTimeout | The timeout for connecting to the URL in milliseconds. Default is 10,000. [optional] |
| Int | readTimeout | The read timeout for the operation in milliseconds. Default is 60,000. [optional] |
| String | username | If specified, the call will attempt to authenticate with basic HTTP authentication. [optional] |
| String | password | The password used for basic HTTP authentication, if the username parameter is also present. [optional] |
| Dictionary[String, String] | headerValues | A dictionary of name/value pairs that will be set in the HTTP header. [optional] |
| Boolean | bypassCertValidation | If the target address in an HTTPS address, and this parameter is true, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates. [optional] |
Returnsβ
String - The content returned for the PUT operation.
Scopeβ
Syntaxβ
system.net.httpPut(url, putParams)
Parametersβ
| String | url | The URL to send the request to. |
| Dictionary[String, Integer] | putParams | A dictionary of name/value key pairs to use as the put data. |
Returnsβ
Scopeβ
Code Examplesβ
Code Example - Simple Test
# The following example uses a test URL to echo back the data used in the PUT request.
# Test URL courtesy of:
# http://stackoverflow.com/questions/5725430/http-test-server-that-accepts-get-post-calls?answertab=votes#tab-top
# Specify URL and parameters to pass in the PUT call
URL = "http://httpbin.org/put"
params = {"testkey":"testValue"}
# Make the PUT request and print the results to the console
print system.net.httpPut(URL, params)
Code Example - Keyword Arguments
This example attempts to authenticate with a username and password, as well as specify a MIME type.
The Username and password are static in this example, but could easily make use of other components to allow user input
or fetch data out of a database instead.
user = "myUser"
userPass = "password"
print system.net.httpPut(URL, params, username = user, password = userPass, contentType = "text/html")
