system.device.setDeviceEnabled
Enables/disables a device in Ignition.
Permission Type: Device Management
system.device.setDeviceEnabled(deviceName, enabled)
StringdeviceNameThe name of the device in Ignition.
BooleanenabledWhether to set the device as enabled or disabled.
Nothing
All
Example 1
# Example 1: Enable a device
system.device.setDeviceEnabled("CLX", 1)
Example 2
# Example 2: Disable a device
system.device.setDeviceEnabled("CLX", 0)
