system.date.setTime
Takes in a date, and returns a copy of it with the time fields set as specified.
system.date.setTime(date, hour, minute, second)
DatedateThe starting date.
InthourThe hours (0-23) to set.
IntminuteThe minutes (0-59) to set.
IntsecondThe seconds (0-59) to set.
Date - A new date, set to the appropriate time.
All
Example #1
# This example will set the date object to the current date with the time set to 01:37 in the morning and 44 seconds.
date = system.date.getDate(2018, 6, 29) #getDate is zero based, so a month parameter of 6 will return July.
print system.date.setTime(date, 1, 37, 44) #This will print Fri July 29 01:37:44 PDT 2018
