system.date.parse
New in 7.9.1
Attempts to parse a string and create a Date. Causes ParseException if the date dateString parameter is in an unrecognized format.
system.date.parse(dateString, formatString, locale)
StringdateStringThe string to parse into a date.
StringformatStringFormat string used by the parser. Default is "yyyy-MM-dd HH:mm:ss" [optional]
ObjectlocaleLocale used for parsing. Can be the locale name such as 'fr', or the Java Locale such as 'Locale.French'. Default is 'Locale.English'. Click here for a list of supported locales and and values. [optional]
Date - The parsed date.
All
Example #1
# This example will return a date object set to the given date and time, May 28th, 1992 at 4:22am.
print system.date.parse('May 28, 1992 4:22', 'MMMM dd, yyyy hh:mm')
Example #2
# This example demonstrates the locale parameter to parse a French date
print system.date.parse("juillet 15, 2015 10:32:15", "MMMM dd, yyyy hh:mm:ss", "fr")
# If using the Java Locale, then you must import from the Locale class. The following example parses a German date.
from java.util import Locale
print system.date.parse('21-Februar-2017 04:22:00', 'dd-MMMM-yyyy HH:mm:ss', Locale.GERMAN)
