Report Viewer Scripting Functions
This page details the various component and extension functions available for Vision's Report Viewer component.
Component Functions​
.print(printerName, showDialog)​
note
The following print method will only work if a report has finished loading on the Report Viewer component.
  • Description
    • Uses the named printer and determine if the print dialog window should appear or not.
  • Parameters
    • String printerName - The name of the printer the report should be sent to. Will use the default printer if left blank. [optional]
    • Boolean showDialog - True if the dialog window should appear, False if the dialog window should be skipped. Will be true if left blank. [optional]
  • Return
    • None
  • Scope
    • Client
getBytesPDF()​
  • Description
    • Return the bytes of the generated report in the Report Viewer using PDF format.
  • Parameters
    • None
  • Return
    • Byte Array - The bytes of the report in PDF format.
    note
    This function will return null if the trial has expired.
  • Scope
    • Client
getBytesPNG()​
  • Description
    • Return the bytes of the generated report in the Report Viewer using PNG format.
  • Parameters
    • Nothing
  • Return
    • Byte Array - The bytes of the report in PNG format.
    note
  • Scope
    • Client
saveAsPDF(fileName)​
  • Description
    • Prompts the user to save a copy of the report as a PDF. Shows a file selection window with the extension set to PDF.
  • Parameters
    • String fileName - A suggested filename to save the report as
  • Return
    • Nothing
  • Scope
    • Client
saveAsPNG(fileName)​
  • Description
    • Prompts the user to save a copy of the report as a PNG. Shows a file selection window with the extension set to PNG.
  • Keyword Args
    • String fileName - A suggested filename to save the report as.
  • Return
    • Nothing
  • Scope
    • Client
saveAsXls(fileName)​
  • Description
    • Prompts the user to save a copy of the report as an XLS file. Shows a file selection window with the extension set to XLS.
  • Keyword Args
  • Return
    • Nothing
  • Scope
    • Client
Extension Functions​
onReportGenerated​
  • Description
    • Called when the Report generation process has been completed.
  • Keyword Args
    • Component self - A reference to the component invoking this method.
    • Byte Array pdfBytes - The PDF formatted bytes generated by the Report.
  • Return
    • Nothing
  • Scope
    • Client
