system.serial.readBytesAsString
Read numberOfBytes bytes from a serial port and convert them to a String. If a specific encoding is needed to match the source of the data, use system.serial.readBytes and use the desired encoding to decode the byte array returned.
system.serial.readBytesAsString(port, numberOfBytes [, timeout])
StringportThe previously configured serial port to use.
intnumberOfBytesThe number of bytes to read.
inttimeoutMaximum amount of time, in milliseconds, to block before returning. Default is 5000. [optional]
String - A String created from the bytes read.
All
