system.alarm.cancel
Cancels any number of alarms, specified by their event ids. The event id is generated for an alarm when it becomes active, and is used to identify a particular event from other events for the same source. The alarm will still be active, but will drop out of alarm pipelines.
Permission Type: Alarm Management
system.alarm.cancel(alarmIds)
String[]alarmIdsList of alarm event ids (uuids) to cancel.
Nothing
All
Example #1
# This example shows the basic syntax for cancelling an alarm.
system.alarm.cancel(['c27c06d8-698f-4814-af89-3c22944f58c5'])
Example #2
# To cancel all currently active alarms:
ids = []
results = system.alarm.queryStatus(state=["ActiveUnacked", "ActiveAcked"])
for result in results:
id = result.getId()
ids.append(str(id))
system.alarm.cancel(ids)
