Power Table Scripting Functions
This page details the various component and extension functions available for Vision's Power Table component.
Component Functions​
.getSelectedColumns()​
  • Description
    • Returns a list of ints representing the currently selected columns.
  • Parameters
    • none
  • Return
    • Object of Integers - An object containing integers that represent the indices of the selected columns. Can be iterated over in a similar manner to a Python List.
  • Scope
    • Client
.getSelectedRows()​
  • Description
    • Returns a list of ints representing the currently selected rows.
  • Parameters
    • none
  • Return
    • Object of Integers - An object containing integers that represent the indices of the selected rows. Can be iterated over in a similar manner to a Python List.
  • Scope
    • Client
.print([fitWidth] [, headerFormat] [, footerFormat] [, showDialog] [, landscape])​
  • Description
    • This specialized print function will paginate the table onto multiple pages.This function accepts keyword-style invocation.
  • Keyword Args
    • boolean fitWidth - If true, the table's width will be stretched to fit across one page's width. Rows will still paginate normally. If false, the table will paginate columns onto extra pages. (default = true) [optional]
    • String headerFormat - A string to use as the table's page header. The substring "0" will be replaced with the current page number. (default = None) [optional]
    • String footerFormat - A string to use as the table's page footer. The substring "0" will be replaced with the current page number. (default = "Page 0") [optional]
    • boolean showDialog - Used to determine if the print dialog should be shown to the user. Default is true. [optional]
    • boolean landscape - Used to specify portrait (0) or landscape (1) mode. Default is portrait (0). [optional]
  • Return
    • boolean - True if the print job was successful.
  • Scope
    • Client
.setColumnWidth(column, width)​
  • Description
    • Used to set a column's width at runtime.
  • Parameters
    • int column - Column to adjust.
    • int width - Width in pixels.
  • Return
    • Nothing
  • Scope
    • Client
Extension Functions​
configureCell​
  • Description
    • Provides a chance to configure the contents of each cell. Returns a dictionary of name-value pairs with the desired attributes. Available attributes (and their Java types) include: 'background' (color), 'border' (border), 'font' (font), 'foreground' (color), 'horizontalAlignment' (int), 'iconPath' (string), 'text' (string), 'toolTipText' (string), 'verticalAlignment' (int).
      You can also specify the attribute 'renderer', which is expected to be a javax.swing.JComponent which will be used to render the cell.
  • Parameters
    • Component self - A reference to the component that is invoking this function.
    • Object value - The value in the dataset at this cell.
    • string textValue - The text the table expects to display at this cell (may be overriden by including 'text' attribute returned in dictionary).
    • boolean selected - A boolean indicating whether this cell is currently selected.
    • int rowIndex - The index of the row in the underlying dataset.
    • int colIndex - The index of the column in the underlying dataset.
    • string colName - The name of the column in the underlying dataset.
    • int rowView - The index of the row, as it appears in the table view (affected by sorting).
    • int colView - The index of the column, as it appears in the table view (affected by column re-arranging and hiding).
  • Return
    • Dictionary of Attributes
  • Scope
    • Client
configureEditor​
  • Description
    • Provides a chance to configure how each column is edited. Returns a dictionary of name-value pairs with desired editor attributes. Visual attributes to modify existing editors include: 'background', 'border', 'font', 'foreground', 'horizontalAlignment', 'toolTipText', and 'verticalAlignment'.
      If the attribure 'options' is specified, it is expected to be a list of tuples representing (value, label). The editor in this case will become a dropdown list.
      If the attribute 'editor' is specified, it is expected to be an instance of javax.swing.table.TableCellEditor, and other attribute will be ignored.
  • Parameters
  • Return
    • Dictionary of name value pairs
  • Scope
    • Client
configureHeaderStyle​
  • Description
    • Provides a chance to configure the style of each column header. Return a dictionary of name-value pairs with the designed attributes. Availible attributes include: 'background', 'border', 'font', 'foreground', 'horizontalAlignment', 'toolTipText', 'verticalAlignment'
  • Parameters
  • Return
  • Scope
    • Client
initialize​
  • Description
    • Called when the window containing this table is opened, or the template containing it is loaded. Provides a chance to initialize the table further, for example, selecting a specific row.
  • Parameters
  • Return
    • Nothing
  • Scope
    • Client
isCellEditable​
  • Description
    • Returns a boolean that determines whether or not the current cell is editable.
  • Parameters
    • int rowIndex - Index of the row that was edited, relative to the underlying dataset.
    • int colIndex - Index of the column that was edited, relative to the underlying dataset.
    • string colName - Name of the column in the underlying dataset.
    • Object value - The value at the cell location.
  • Return
    • boolean
  • Scope
    • Client
onCellEdited​
  • Description
    • Called when the user has edited a cell in the table. It is up to the implementation of this function to alter the underlying data that drives the table. This might mean altering the dataset directly, or running a SQL UPDATE query to update data in the database.
      Caution: If the script on this extension function causes the Power Table to lose focus, the cell commit will occur twice. For example, if system.gui.confirm() is called, then two confirmation boxes will appear. In cases where the script will cause the focus to switch between multiple objects, the script should be placed in a function, and wrapped in a call to system.util.invokeLater()
    def myFunction():
    Do your work here
    system.gui.messageBox("Assuming you don't change focus outside of this script\nYou will only see this message once per cell edit")
    system.util.invokeLater(myFunction)
  • Parameters
    • Object oldValue - The old value at the location, before it was edited.
    • Object newValue - The new value input by the user.
  • Return
    • Nothing
  • Scope
    • Client
onMousePress​
  • Description
    • Called when the user clicks on a table cell.
  • Parameters
    • int rowIndex - Index of the row, starting at 0, relative to the underlying dataset.
    • int colIndex - Index of the column starting at 0, relative to the underlying dataset.
    • Object value - The value at the location clicked on.
    • MouseEvent event - The MouseEvent object that caused this click event.
  • Return
    • Nothing
  • Scope
    • Client
onDoubleClick​
  • Description
    • Called when the user double-clicks on a table cell.
  • Parameters
    • MouseEvent event - The MouseEvent object that caused this double-click event.
  • Return
    • Nothing
  • Scope
    • Client
onPopupTrigger​
  • Description
    • Called when the user right-clicks on a table cell. This would be the appropriate time to create and display a popup menu.
  • Parameters
  • Return
    • Nothing
  • Scope
    • Client
onRowsDropped​
  • Description
    • Called when the user has dropped rows on this table. Note that the rows may have come from this table or another table. The source table must have dragging enabled.
  • Parameters
    • Component sourceTable - A reference to the table that the rows were dragged and dropped in the same table.
    • list rows - An array of the rows indices that were dragged, in the order they were selected.
    • Dataset rowData - A dataset containing the rows that were dragged.
    • int dropIndexLocation - Row index where the rows were dropped.
  • Return
    • Nothing
  • Scope
    • Client
