Power Table
Component Palette Icon:
Inductive University
Power Table
Watch the video
The power table is a much more customizable version of the table component, and has many more features. The power table contains advanced features such as drag-and-drop rows, multi-column sorting, column filtering, and cell-spanning. Customization comes through extensive use of extension functions, which are available to configure how each cell of the table looks, how the headers look, etc.
Basic Usage​
The basics are just like the classic table - you simply bind the table's "data" property to your data, most often by using a SQL query binding. Note that many of the options built into the classic table have been moved to extension functions in the power table.
Power Table Features​
  • Multi-column sorting: To sort multiple columns, select the header of the first column, hold down the Control key, then select the header of the next column. Click on the header again to reverse the sort order, and click a third time to remove sorting on the column.
  • Column filtering: Columns can be temporarily hidden from view using column filtering. Right-click on the header of the table, and uncheck columns that you would like to hide. You can disable this feature by disabling the Column Chooser Menu property on the table.
  • Column reordering: You can switch the locations of columns on the table using column reordering. Drag the header of the column that you would like to move to a new location on the table. You can disable this feature by disabling the Columns Re-Orderable property on the table.
  • Cell spanning: A cell can be spanned across multiple columns and rows. Keep in mind that you must explicitly define the locations of cells that must be spanned. This means that if you would like to use cell spanning, any other table features that change how the table is displayed will be disabled automatically (such as sorting, column filtering and column reordering). Click on the Cell Span Data dataset to configure spanning. Within the dataset, add a row for each new span. The "row" column controls the row in the table where the span will start. The "column" column controls the column where the span will start. The "width" column controls how many columns the span will cover. The "height" column controls how many rows the span will cover. Adding a row where "row=4, column=1, width=2, height=3" results in a span starting on the fifth row of the table and the second column (using 0-based indexing). The span will cover the second and third columns in the row and will also cover two rows below the fifth row, as shown below.
  • Drag and Drop: This feature allows you to drag rows from one power table to another power table. In order to perform drag and drop, you must implement the onRowsDropped() extension function on the destination table. This is so that you can adapt the data from one table to the other within the function. You must also enable the Row Dragging Enabled property on both tables.
  • Row Copying: This feature allows you to select rows and copy them to the clipboard using the standard keyboard shortcut Ctrl + C. These can then be pasted anywhere, even outside of Ignition.
caution
Even if a column is set to be editable, the edit must be handled by the onCellEdited extension function. If that extension function is not enabled and properly set up, the cell will revert back to its previous value.
Properties​
NameDescriptionProperty TypeScriptingCategory
AntialiasDraw with antialias on? Makes text smoother.boolean.antialiasAppearance
Auto Row HeightEnables automatic resizing of row height.boolean.rowResizeEnabledBehavior
Auto-Resize ModeDetermines how the table resizes the columns.int.autoResizeModeBehavior
Background ColorThe background color of the component.Color.backgroundAppearance
Cell Span DataThis dataset holds information about how cells in the table span multiple rows and/or columns. Incompatible with column sorting and re-ordering.Dataset.cellSpanDataData
Column Attributes DataThe dataset describing the column attributes.
Note: the data in this property doesn't get initialized until the customizer is opened and the OK button is pressed.
Dataset.columnAttributesDataAppearance
Column Chooser MenuEnables a right-click popup menu on the column headers with options to show and hide columns.boolean.headerColumnChooserMenusBehavior
Column Resize MenuEnables a right-click popup menu on the column headers with resizing options.boolean.headerResizeMenusBehavior
Column Selection AllowedThis flag is used in conjunction with the Row Selection Allowed flag to determine whether not whole-rows, whole-columns, or both (single-cells) are selectable.boolean.columnSelectionAllowedBehavior
Column SizingRepresents column sizing and position to preserve user-selected ordering.String.defaultColumnViewAppearance
Columns Re-OrderableEnables the re-ordering of columns by dragging the column headers.boolean.columnReorderingAllowedBehavior
Columns ResizableEnables the resizing of columns by dragging the margins of the column headers.boolean.columnResizingAllowedBehavior
CursorThe mouse cursor to use when hovering over this component.int.cursorCodeCommon
DataThe data for this table.Dataset.dataData
Data QualityThe data quality code for any tag bindings on this component.int.dataQualityData
Edit Click CountThe number of clicks required to start editing a cell.int.clickCountToStartBehavior
EnabledIf disabled, a component cannot be used.boolean.componentEnabledCommon
FontFont of text on this component.Font.fontAppearance
Foreground ColorThe foreground color of the component.Color.foregroundAppearance
Grid Line ColorThe color used to draw grid lines.Color.gridColorAppearance
Header FontFont of the table's header text.Font.headerFontAppearance
Header VisibleAllows for hiding of the table's header.boolean.headerVisibleAppearance
Inter Cell SpacingThe space (in pixels) between the cells.Dimension.interCellSpacingAppearance
NameThe name of this component.String.nameCommon
Non-Contiguous SelectionEnables totally non-contiguous selection in the table.boolean.nonContiguousCellSelectionBehavior
Properties LoadingThe number of properties currently being loaded. (Read only. Usable in bindings and scripting.)int.propertiesLoadingUncategorized
Row Dragging EnabledEnables drag-and-drop re-ordering for table rows. Implementing the 'onRowsDropped' extension function is also required to have functional drag-and-drop.boolean.rowDragEnabledBehavior
Row HeightIf row resizing is disabled, this will set the height of all rows.int.rowHeightBehavior
Row Selection AllowedThis flag is used in conjunction with the Column Selection Allowed flag to determine whether not whole-rows, whole-columns, or both (single-cells) are selectable.boolean.rowSelectionAllowedBehavior
Selected ColumnThe index of the first selected column, or -1 if none.int.selectedColumnData
Selected RowThe index of the first selected row, or -1 if none.int.selectedRowData
Selection BackgroundThe default background color of selected cells.Color.selectionBackgroundAppearance
Selection ForegroundThe default foreground color of selected cells.Color.selectionForegroundAppearance
Selection ModeThis mode determines if only one row/cell/column can be selected at once, or single or multiple intervals.int.selectionModeBehavior
Show Horizontal Grid Lines?Shows horizontal grid lines.boolean.showHorizontalLinesAppearance
Show Vertical Grid Lines?Shows vertical grid lines.boolean.showVerticalLinesAppearance
Sorting EnabledEnables automatic multi-column sorting by clicking and CTRL-clicking on the table header.boolean.sortingEnabledBehavior
TestDataToggle this property to True to fill in the table's data with random data. It will immediately reset itself to False but leave the data.boolean.testMisc
View DatasetA read-only copy of the data as it appears on screen in the table.Dataset.viewDatasetData
VisibleIf disabled, the component will be hidden.boolean.visibleCommon
Scripting​
See the Power Table Scripting Functions page for the full list of scripting functions available for this component.
Event Handlers​
Event handlers allow you to run a script based off specific triggers. See the full list of available event handlers on the Component Events page.
Customizers​
This component has a table customizer that allows customization of the individual columns including hiding columns, enabling editing, changing format, etc. It is important to note that when editing cells directly in the Power Table, it doesn't modify the underlying Dataset. You can use the onCellEdited extension function and uncomment the sample code to make table edits change the underlying Dataset, or even the original source of data (ie: if using a SQL Query).
Example​
Code Snippet
#Example of an onRowsDropped() extension script for two power tables with identical columns:
def onRowsDropped(self, sourceTable, rows, rowData, dropIndexLocation):
if self != sourceTable:
destDataset = self.getData()
pyRowData = system.dataset.toPyDataSet(rowData)
# Loop thru all the rows that have been selected and dragged to the
# destination table.
for row in pyRowData:
newRow = []
for column in row:
newRow.append(column)
destDataset = system.dataset.addRow(destDataset, dropIndexLocation, newRow)
# Adds the rows to the destination table.
self.setData(destDataset)
# Optional. Deletes the dragged rows from the source table.
sourceDataset = system.dataset.deleteRows(sourceTable.getData(), rows)
sourceTable.setData(sourceDataset)
else:
system.gui.messageBox("Dropping on to same table not supported")
# To drop onto the same table, the new row indices must be calculated
# for both the dropped and deleted rows, taking changes into account.
