system.perspective.vibrateDevice
Descriptionβ
When called from the Perspective App, will cause the device to vibrate for the specified number of milliseconds.
note
iOS vibration duration is fixed. This function will cause an iOS device to vibrate for its default duration, 0.4 seconds (400 milliseconds).
Syntaxβ
system.perspective.vibrateDevice(integer, [sessionId])
Parametersβ
| String | duration | The duration in milliseconds to vibrate the device. Note: iOS vibration duration is fixed. Thus, this parameter will not impact the vibration duration on devices running iOS. |
| String | sessionId | Identifier of the Session to target. If omitted, the current Session will be used automatically. |
Returnsβ
Nothing
Scopeβ
Gateway, Perspective Session
note
This function will only work in the Gateway scope if sessionId is supplied to the call.
Code Examplesβ
Code Snippet - View
# Vibrates the device for 1/2 second (500 milliseconds).
system.perspective.vibrateDevice(500)
