Version: 8.1
system.perspective.setTheme
Changes the theme in a page to the specified theme.
Note that this function only changes the theme for a single page, not the entire session. To change the theme for a session, write directly to the session.theme property instead.
system.perspective.setTheme(name, [sessionId], [pageId])
StringnameThe theme name to switch to. Possible values are "dark" or "light".
StringsessionIdIdentifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional]
StringpageIdIdentifier of the page to target. If omitted, the current page will be used automatically. [optional]
Nothing
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId and pageId are supplied to the call.
Code Snippet - Changing Session Theme
# Change the current page's theme to the dark theme.
system.perspective.setTheme("dark")
