system.perspective.closePage
Closes the page with the given page id or the current page if no page id is provided. If a message is provided, it is displayed on the page when the page closes. Otherwise the default message (set in the Project properties) is displayed.
system.perspective.closePage([message], [sessionId], [pageID])
Type | Parameter | Description |
String | message | The message to display when the page closes. If omitted, the default message (set in the Project Properties) is shown. [optional] |
String | sessionId | Identifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different Session, the pageId parameter must be included in the call. [optional] |
String | pageId | Identifier of the page to be closed. If omitted, the current pageId is used. [optional] |
Nothing
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId
and pageId
are supplied to the call.
Code Snippet
# Closes the page with the given pageId.
system.perspective.closePage('Your page has been closed.')
