system.perspective.toggleDock
Descriptionβ
Toggles a docked view.
Syntaxβ
system.perspective.toggleDock(id, [sessionId], [pageId])
Parametersβ
| String | id | The unique, preconfigured 'Dock ID' for the docked view. Is specified when a view is assigned as docked for a particular page (in Page Configuration). |
| String | sessionId | Identifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional] |
| String | pageId | Identifier of the Page to target. If omitted, the current Page will be used automatically. [optional] |
| Dictionary[String, String] | params | Parameters that can be passed into the docked view. Must match the docked views View Parameters. [optional] |
Returnsβ
Nothing
Scopeβ
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId and pageId are supplied to the call.
Code Examplesβ
Code Snippet
# Toggles a docked view with ID "myDockID". We are passing in two parameters, called "myParam" and "myParam2".
system.perspective.toggleDock('myDockID', params = {'myParam':1,'myParam2':'Test'})
