Version: 8.1
system.perspective.closeSession
Closes the Perspective Session with the given sessionID or the current Session if no ID is provided. If a message is provided, it is displayed on the page when the Session closes. Otherwise the default message (set in the Project properties) is displayed.
note
In the Perspective App, the user is returned to the launch screen.
system.perspective.closeSession([message], [sessionId])
StringmessageThe message to display when the Session closes. If omitted, the default message (set in the Project properties) is shown. [optional]
StringsessionIdIdentifier of the Session to be closed. If omitted, the current sessionId is used. [optional]
Nothing
Gateway, Perspective Session
note
This function will only work in the Gateway scope if sessionId is supplied to the call.
Code Snippet
# Closes the Session with the given sessionId.
system.perspective.closeSession('Your Session has ended.','2e1c98a8-182e-43ce-84e8-a71d441c2cce')
