system.perspective.closePopup
Descriptionβ
Closes a popup view.
Syntaxβ
tip
system.perspective.closePopup(id, [sessionId], [pageId])
Parametersβ
| String | id | The unique identifier for the popup, given to the popup when first opened. If given an empty string, then the most recently focused popup will be closed. |
| String | sessionId | Identifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional] |
| String | pageId | Identifier of the page to target. If omitted, the current Page will be used automatically. [optional] |
Returnsβ
Nothing
Scopeβ
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId and pageId are supplied to the call.
Code Examplesβ
Code Snippet
# Closes the popup with the given id.
system.perspective.closePopup('popup 4')
Code Snippet
# Closes the last focused popup
system.perspective.closePopup('')
