Version: 8.1
Perspective - Image
Component Palette Icon:
The Image component displays either vector or raster format images, such as a JPG, JPEG, GIF, PNG, or SVG. Images can be added directly to the component or dropped onto a view to then be displayed by this component. Refer to the Images and Icons in Perspective page for more information on using images in projects.
The Image component can also be used to show external images stored relative to the local file system on the client. The file path is similar to having your browser view a local document.
Properties​
NameDescriptionProperty Type
sourceThe image source URL. It can be a URL to an image on the internet or Gateway, or even an embedded image.
If you use images in the Image Management tool, simply copy their path for this source property, using the format /system/images/<imagepath>. For example, the Builtin/icons/16/about.png image path would be /system/images/Builtin/icons/16/about.png
Additionally, the source can be set to a Base64 encoded image.
value: string
altTextAn alternate text for the image if the image cannot be displayed because of a slow connection, an error in the source attribute, if the user uses a screen reader, or some other reason.value: string
fitWhether or not the image will size to fit. When in percent mode, the parameters are used to fit based on the percentage of the width and height. When in absolute mode, the image will fit the width and height sizes in pixels.
  • mode: Can be one of the following modes: none, fill, contain, cover, percent, or absolute. Value is string.
  • width: Width of the image in pixels. Value is numeric.
  • height: Height of the image in pixels. Value is numeric.
  • scroll: If false, scrolling is not enabled. Value is boolean.
object
tintEnables you to tint the entire image a color.
  • enabled: Turn tint on (true) and off (false). Value is boolean.
  • color: If the tint filter is on, this is the color of the tint. See Color Selector.
object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. Classes are predefined styles in a project.object
Component Events​
Examples​
Example 1​
PropertyValue
props.source/system/images/Builtin/Flow/Flow 7.png
props.fit.modecontain
props.tint.enabledtrue
props.tint.color#FFF00
position.width150
position.height115
Example 2​
PropertyValueStyle Category
props.sourcehttps://inductiveautomation.com/static/images/logos/inductive-automation-logo.pngN/A
props.style.borderStylesolidborder
props.style.borderWidth1pxborder
