Perspective - Linear Scale
Component Palette Icon:
Description
The Linear Scale component displays a series of tick marks and labels that represent a range between a minimum value and a maximum value. It also displays indicators that represent a value or range of values, correctly positioned on the linear scale.
Linear Scale component allows floating point tick marks such as 0.25, 0.5, 0.75, 1.25, etc.
Properties
| minValue | The minimum value displayed on the scale. | value: numeric |
| maxValue | The maximum value displayed on the scale. | value: numeric |
| majorTicks | Settings for the major tick marks on the scale. See the majorTicks properties. | object |
| minorTicks | Settings for the minor tick marks on the scale. See the minorTicks properties. | object |
| fineTicks | Settings for the fine tick marks on the scale. See the fineTicks properties. | object |
| labels | Displays of the numeric values of major tick marks. Options are as follows:
| object |
| indicators | Markers of special significance that can be placed along the scale. Click here to see the indicators properties. | object |
| mirror | Aligns the scale to the opposite side of the component. Default is false. | value: boolean |
| reverse | Inverts the order of the scale values so min to max is ordered in reverse. Default is false (minimum to max). | value: boolean |
| style | Sets a style for this scale. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Tick Child Properties
The following child properties apply to majorTicks, minorTicks, and fineTicks.
| span | Distance between each tick mark of this type, in pixels. Default is 20. | value: numeric |
| length | Length of each tick mark, in pixels. Default is 20. | value: numeric |
| color | Color for the major ticks. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector. | color |
| stroke | Width of each tick mark, in pixels. Default is 1. | value: numeric |
indicators Child Properties
| value | Numeric value along the scale where the indicator is placed or started. | value: numeric |
| label | Text to display with the indicator. Default is "High". | value: string |
| labelColor | Color of the indicator label. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector. | color |
| labelAngle | Rotational angle of the indicator label. | value: numeric |
| color | Color of the indicator or the area making up the indicator. See Color Selector. | color |
| stroke | If indicatorStyle is set to line or wedge, stroke is the width (in pixels) of the indicator. | value: numeric |
| opacity | Opacity of the indicator. 0 is fully transparent, 1 is fully opaque. | value: numeric |
| length | Length of the indicator as measured by its x value within the scale. Default is 25. | value: numeric |
| indicatorStyle | Indicator style can be set to line, wedge, or range. Line is similar to a tick mark. Wedge displays a triangular shape. Range displays a rectangular range along the scale as measured by the property extent. Default is range. | value: string dropdown |
| extent | If indicatorStyle is set to range, this is the extent along the scale that the indicator is placed. Value must be positive. Default is 15. | value: numeric |
Component Events
Example
| Property | Value |
| props.maxValue | 120 |
| props.minorTicks.span | 10 |
| props.fineTicks.span | 5 |
| props.indicators.0.value | 95 |
| props.indicators.0.color | #D90000 |
| props.indicators.0.extent | 25 |
| props.indicators.1.value | 00 |
| props.indicators.1.indicatorStyle | range |
| props.indicators.1.color | #D9D900 |
| props.indicators.1.extent | 20 |
| props.indicators.2.value | 74 |
| props.indicators.2.indicatorStyle | wedge |
| props.indicators.2.color | #0000D9 |
