Version: 8.3
Perspective - Linear Scale
Component Palette Icon:
The Linear Scale component displays a series of tick marks and labels that represent a range between a minimum value and a maximum value. It also displays indicators that represent a value or range of values, correctly positioned on the linear scale.
Linear Scale component allows floating point tick marks such as 0.25, 0.5, 0.75, 1.25, etc.
Properties​
NameDescriptionProperty Type
minValueThe minimum value displayed on the scale.value: numeric
maxValueThe maximum value displayed on the scale.value: numeric
majorTicksSettings for the major tick marks on the scale. See the majorTicks properties.object
minorTicksSettings for the minor tick marks on the scale. See the minorTicks properties.object
fineTicksSettings for the fine tick marks on the scale. See the fineTicks properties.object
labelsDisplays of the numeric values of major tick marks. Options are as follows:
  • angle: Rotation of the numeric labels. Default is 0. Value is numeric.
  • style: Sets a style for the label. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
indicatorsMarkers of special significance that can be placed along the scale. Click here to see the indicators properties.object
mirrorAligns the scale to the opposite side of the component. Default is false.value: boolean
reverseInverts the order of the scale values so min to max is ordered in reverse. Default is false (minimum to max).value: boolean
styleSets a style for this scale. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Tick Child Properties​
The following child properties apply to majorTicks, minorTicks, and fineTicks.
spanDistance between each tick mark of this type, in pixels. Default is 20.value: numeric
lengthLength of each tick mark, in pixels. Default is 20.value: numeric
colorColor for the major ticks. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.color
strokeWidth of each tick mark, in pixels. Default is 1.value: numeric
indicators Child Properties​
valueNumeric value along the scale where the indicator is placed or started.value: numeric
labelText to display with the indicator. Default is "High".value: string
labelColorColor of the indicator label. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.color
labelAngleRotational angle of the indicator label.value: numeric
colorColor of the indicator or the area making up the indicator. See Color Selector.color
strokeIf indicatorStyle is set to line or wedge, stroke is the width (in pixels) of the indicator.value: numeric
opacityOpacity of the indicator. 0 is fully transparent, 1 is fully opaque.value: numeric
lengthLength of the indicator as measured by its x value within the scale. Default is 25.value: numeric
indicatorStyleIndicator style can be set to line, wedge, or range. Line is similar to a tick mark. Wedge displays a triangular shape. Range displays a rectangular range along the scale as measured by the property extent. Default is range.value: string dropdown
extentIf indicatorStyle is set to range, this is the extent along the scale that the indicator is placed. Value must be positive. Default is 15.value: numeric
Component Events​
Example​
PropertyValue
props.maxValue120
props.minorTicks.span10
props.fineTicks.span5
props.indicators.0.value95
props.indicators.0.color#D90000
props.indicators.0.extent25
props.indicators.1.value00
props.indicators.1.indicatorStylerange
props.indicators.1.color#D9D900
props.indicators.1.extent20
props.indicators.2.value74
props.indicators.2.indicatorStylewedge
props.indicators.2.color#0000D9
