Version: 8.1
Perspective - Progress
Component Palette Icon:
The Progress bar visually indicates the progress of a task. It is used to display any value that has an upper and lower bound. Custom settings are available for the track and the bar.
Properties​
NameDescriptionProperty Type
minThe minimum value of the progress indicator. If the value reaches the max, the progress indicator will be completely filled. Must be less than the max. Default is 0.value: numeric
maxThe maximum value of the progress indicator. If the value reaches the max, the progress indicator will be completely filled. Must be greater than 0.0. Default is 100.value: numeric
valueThe current value representing the current progress. Must be greater than 0.0 and less than the value set in max. Default is 50.value: numeric
modeDetermines if the component should show a determinate state, or an indeterminate loading state. When set to determinate, shows the progress of the value relative to the min and max properties.value: string
barSettings for the bar. Full property descriptions included below.object
trackSettings for the track. Full property descriptions included below.object
valueDisplayValue display configuration. Renders and styles a value overlay above the progress bar.
  • enabled: If true, will show the value display. Value is boolean.
  • format: Format to apply to value, which is then used in the value display. Value is string.
  • justify: Horizontal alignment of the displayed value. Value is string.
  • style: Sets a style for the track. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
bar and track Child Properties​
colorA convenience property for setting the base color. This can also be accomplished by using the prop.bar.style or prop.track.style to set the background color.object
styleSets a style. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
determinateDeterminate configuration.
  • color: A convenience property for setting the color when mode is determinate. This can also be accomplished by using the prop.bar.determinate.style or prop.track.determinate.style to set the background color.
  • style: Sets a style for the bar when mode is determinate. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
indeterminateIndeterminate configuration.
  • color: A convenience property for setting the color when mode is indeterminate. This can also be accomplished by using the prop.bar.indeterminate.style or prop.track.indeterminate.style to set the background color.
  • style: Sets a style for the bar when mode is indeterminate. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
object
Component Events​
Examples​
Example 1​
PropertyValue
max100
value80
Example 2​
PropertyValue
max100
value56
modedeterminate
bar.color#FFAC47
track.color#FFE8CC
track.borderStylesolid
track.borderWidth2
track.borderBottomLeftRadius15
track.borderBottomRightRadius15
track.borderTopRightRadius15
track.borderTopLeftRadius15
track.borderColor#A45324
valueDisplay.enabledtrue
valueDisplay.formatpercent
valueDisplay.justifycenter
valueDisplay.fontFamilyMerriweather
valueDisplay.fontWeightbold
