Version: 8.1
Perspective - Barcode
Component Palette Icon:
The Barcode component enables you to display text as a barcode. The component supports 105 different barcode types including Code 128, QR code, EAN-8, and ISBN.
New in 8.1.2
The Barcode component has two pre-configured variants: Code 128 and QR Code.
Properties​
NameDescriptionProperty Type
valueValue to be encoded as a barcode.value: numeric
typeWhat barcode specification to use, currently there are 105 formats supported including Code 128, QR code, EAN-8, and ISBN. Click here to see the barcode specification options.value: string
displayValueIf true, the barcode's value will be displayed as text.value: boolean
valuePositionIf displayValue is true, this property determines where the value should be displayed. Options are top or bottom; default is bottom.value: string
valueStyleSets a style for the display value for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
errorStyleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
styleSets an overall style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Barcode Specification Options​
A-BCDE-G
auspost
azteccode
azteccodecompact
aztecrune
bc412
channelcode,
codablockf,
code11
code128
code16k
code2of5
code32
code39
code39ext
code49
code93
code93ext
codeone
coop2of5
daft
databarexpanded
databarexpandedcomposite
databarexpandedstacked
databarexpandedstackedcomposite
databarlimited
databarlimitedcomposite
databaromni
databaromnicomposite
databarstacked
databarstackedcomposite
databarstackedomni
databarstackedomnicomposite
databartruncated
databaretruncstedcomposite
datalogic2of5
datamatrix
datamatrixrectangular
datamatrixrectangularextension
dotcode
ean13
ean13composite
ean14
ean2
ean5
ean8
ean8composite
flattermarken
gs1-128
GS1-128
gs1-128composite
gs1-cc
gs1datamatrix
gs1datamatrixrectangular
gs1northamericancoupon
gs1qrcode
H-JK-PQ-Z
hanxin
hibcazteccode
hibccodeablockf
hibccode128
hibccode39
hibcdatamatrix
hibcdatamatrixrectangular
hibcmicropdf417
hibcpdf417
hibcqrcode
iata2of5
identcode
industrial2of5
interleaved2of5
isbn
ismn
issn
itf14
japanpost
kix
leitcode
mailmark
matrix2of5
maxicode
micropdf417
microqrcode
msi
onecode
pdf417
pdf417compact
pharmacode
pharmacode2
planet
plessey
posicode
postnet
pzn
qrcode
rationalizedCodabar
raw
royalmail
sscc18
symbol
telepen
telepennumeric
ultracode
upca
upcacomposite
upce
upcecomposite
Component Events​
Examples​
Example 1​
PropertyValue
props.value014113910613
props.typeupca
props.displayValuetrue
props.valuePositionbottom
props.valueStyle.fontFamilyVerdana
props.valueStyle.fontSize18px
Example 2​
PropertyValue
props.valuehttp://inductiveautomation.com
props.typeqrcode
props.valuePositiontop
props.valueStyle.color#2747C7
props.valueStyle.fontFamilysans-serif
props.valueStyle.fontSize14px
props.valueStyle.fontWeightbold
props.style.paddingTop12px
props.style.borderColorD97700
