Perspective - Audio Scripting
This page details the various scripting, component, and extension functions available for Perspective's Audio component.
Component Events​
onPlay​
This event is fired when playback has begun.
event​
Object Path
- event
Type
- Null
Description
- An empty event object.
onPause​
This event is fired when playback has been paused.
event​
Object Path
- event
Type
- Null
Description
onError​
This event is fired when there is an error attempting to play the media file.
This component event is designed to be used in tandem with a script action. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
event.errorMessage​
Object Path
- event.errorMessage
Type
- String
Description
- Error message when attempting to play the media file.
onEnded​
This event is fired when playback has ended due to reaching the end of the media.
event​
Object Path
- event
Type
- Null
Description
onLoaded​
This event is fired when the first frame of the media has loaded.
event​
Object Path
- event
Type
- Null
Description
onRateChanged​
This event is fired when the playback rate of the media has changed.
event​
Object Path
- event
Type
- Null
Description
Component Functions​
.play()​
Description
- Plays the media file, triggering the onPlay component event.
Parameters
- None
Return
- Nothing
.pause()​
Description
- Pauses the media file, triggering the onPause component event.
Parameters
- None
Return
- Nothing
.replay()​
Description
- Replays the media file from the beginning.
Parameters
- None
Return
- Nothing
Extension Functions​
