Version: 8.1
Perspective - LED Display
Component Palette Icon:
The LED Display is a stylized numeric and/or alphanumeric label. It has two visual styles: 7-segment and 14-segment and supports nine common number format patterns. Use the value property to enter numeric and/or alphanumeric characters.
New in 8.1.2
The LED Display component has two pre-configured variants:
  • 14 Segment - Appearance is that of an LED with 14 light segments.
  • 7 Segment - Appearance is that of an LED with 7 light segments.
Properties​
NameDescriptionProperty Type
valueValue to be displayed.value: numeric
segmentFormatStyle of each character/digit and the number of segments that compose the character. There are two different visual styles: 7 segment and 14 segment. Default is 14 segment.value: string
numberFormatFormat of display for numeric characters, including commas, decimal places, percent, etc. There are nine options available from a dropdown list. Default is #,##0.00.value: string
backgroundColorBackground color of the LED display. Default is #161616. See Color Selector.color
diodeOnColorColor of LED segments when switched on. Default is #1EC963. See Color Selector.color
diodeOffColorColor of LED segments when switched off. Generally different from display background color to preserve analog look. See Color Selector.color
localeLocalization code that determines rules for commas, decimals, etc. Default is en-US.value: string
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
Component Events​
Example​
Example 1​
PropertyValue
props.value12.34
props.segmentFormat7 segment
props.backgroundColor#D5D5D5
props.diodeOnColor#0062FF
props.OffColor#0062FF1A
Example 2​
PropertyValueStyle Category
props.value52,345.9N/A
props.numberFormat#,##0.00N/A
props.backgroundColor#000000N/A
props.diodeOnColor#00FF00N/A
prop.diodeOffColor#000000N/A
props.style.borderStylegrooveborder
props.style.padding2pxmargin and padding
