Perspective - Chart Palette
Chart Componentsβ
Charts allow you to display and show off your data in a graphical way.
The following is a complete list of Chart components that give you various options for displaying data, and a link pointing to a page containing the component's description, properties, and an example of how to configure it.
ποΈ Chart Range Selector
The Chart Range Selector component is a small recreation of a chart that operators can use to select a time range based on seeing the existing data.
ποΈ Gauge
The Gauge component in Perspective provides a way to show realtime values in a range as they change.
ποΈ Pie Chart
A Pie Chart displays a list of named items, each of which has a value that is part of a total.
ποΈ Power Chart
The Power Chart collects and displays data based on the pens that have been configured on the chart.
ποΈ Simple Gauge
The Simple Gauge component in Perspective provides a way to show realtime values in a range as they change.
ποΈ Time Series Chart
The Time Series component provides an efficient way to visualize data from a variety of different data sources as chart data.
