Version: 8.1 View as Markdown
Perspective - Embedding Palette
The following components function a bit differently, but what they all have in common is that each component can be embedded in multiple views of a project.
The Carousel component allows you to display a selection of rotating views. An Embedded View is an instance of a view that is used as a component within another view. The Flex Repeater component lets you easily create multiple instances of components for display in another view, each having the same look, feel, and functionality of the original components.
Here is a complete list of the embedding components, and a link pointing to a page containing the component's description, properties, and an example of how to configure it.
