Perspective - Simple Gauge
Component Palette Icon:
The Simple Gauge component in Perspective provides a way to show realtime values in a range as they change. This gauge is a less complicated version of the Gauge component. It has just one axis, is easy to configure and is customizable in its appearance.
The Simple Gauge component has three pre-configured variants:
- Half Circle - Default layout with a half-circle gauge.
- 3/4 Circle - Layout with a 3/4 circle gauge.
- Full Axis - Layout with a full axis gauge.
Propertiesβ
| value | Numeric value for the gauge to display. Default is 0. | value: numeric |
| minValue | Minimum gauge value for this gauge. Default is 0. | value: numeric |
| maxValue | Maximum gauge value for this gauge. Default is 100. | value: numeric |
| startAngle | Radial position for the start of the gauge's arc. Default is 180. | value: numeric |
| endAngle | Radial position for the end of the gauge's arc. Default is 360. | value: numeric |
| arc | The arc is a radial band that displays the gauge's value.
| object |
| arcBackground | Background or 'track' for the gauge arc. Shows shape and total potential value behind the arc.
| value: numeric |
| label | The label for the gauge is displayed as text, with optional units.
| object |
| animate | Whether needle should be animated in a sweeping motion when value changes. Default is false. | value: boolean |
| style | Sets a style for this gauge. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Component Eventsβ
Exampleβ
| Property | Value |
| Value | 32.4567 |
| props.arc.width | 15 |
| props.arc.cornerRadius | 25 |
| props.arc.color | #FF8C00 |
| props.arcBackground.opacity | 0.4 |
| props.label.units | psi |
| props.label.maxDecimal | 1 |
