Version: 8.1
Perspective - Sparkline
Component Palette Icon:
The Sparkline chart is a minimalistic chart component that displays a line-chart history for a single datapoint. Sparklines were invented by Edward Tufte as a way to show a great deal of contextual information in a very small amount of space. Sparklines are typically used to display the recent history (up to current time) of a datapoint so that the viewer can quickly discern the recent trend of a datapoint: is it rising? falling? oscillating? etc..
To use a sparkline, bind its Data property either to a Tag Historian realtime query, or to a database query. There should be two columns in this dataset: the first one a date column, the second a number. Each row will become a datapoint on the chart, and the dataset must be sorted by time in ascending order.
Instead of using axes to convey scale, the Sparkline can display a band of color across the back of the chart which indicates the desired operating range of the datapoint. In this way, it is instantly obvious when a value is in its expected range, above that range, or below. The sparkline automatically configures its internal axes based on the data given to it. To display a desired range, fill in the props.desired.high and props.desired.low properties.
Properties​
NameDescriptionProperty Type
pointsData points to plot. Accepts the following: May be a dataset, or an array of values or of objects containing X or Y coordinates. Also may be a string formatted with X and Y values separated by a comma.
  • An array of numbers containing X or Y coordinates.
  • A string of space delimited points where x and y are separated by a comma. For example: 0,20 1,35 2,15.
  • An array of objects, where each object contains an x and a y property, and where each property's value is a number.
  • A dataset of a single column of number type.
  • A dataset of two columns, the first representing the x value and the second column representing the y value. The first column can be either of type number or type date. Dates and Timestamps are converted to unix timestamps which is used as the x value.
array or dataset
colorColor of the line. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector.color
widthThickness of the line, in pixels.value: numeric
opacityThe opacity of the line ranging from 0 to 1. 0 is fully transparent, 1 is fully opaque.value: numeric
dashArrayThe pattern of dashes and gaps used to paint the stroke. It's a list of comma separated lengths (in pixels) and percentages (percentage of the total stroke length) that specify the lengths of alternating dashes and gaps. If an odd number of values is provided, then the list of values is repeated to yield an even number of values. Thus, "5,3,2" is equivalent to "5,3,2,5,3,2".array
rangeSettings for the upper and lower edge of the chart.
  • high: A fixed value for the upper edge of the chart as a number.
  • low: A fixed value for the lower edge of the chart as a number.
object
desiredThe desired operating range. Settings for the desired properties operating range.
  • high: The high value of the desired operating range. Value is numeric.
  • low: The low value of the desired operating range. Value is numeric.
  • stroke: Settings for the stroke. Options as follows:
    • width: Width of the line in pixels. Value is numeric.
    • opacity: Opacity of the line ranging from 0 to 1. 0 is fully transparent, 1 is fully opaque. Value is numeric.
    • dashArray: The pattern of dashes and gaps used to paint the stroke. It's a list of space separated lengths (in pixels) and percentages (percentage of the stroke length for the desired operating range) that specify the lengths of alternating dashes and gaps. If an odd number of values is provided, then the list of values is repeated to yield an even number of values. Thus, "5 3 2" is equivalent to "5 3 2 5 3 2".
  • fill: Settings for the fill for the desired range. Options as follows:
    • opacity: Opacity of the fill ranging from 0 to 1. 0 is fully transparent, 1 is fully opaque.
object
markerSettings for the markers on the chart. Each of the following markers have the child properties listed in the marker Type Child Properties table below.
  • first: Settings for the first marker on the chart.
  • last: Settings for the last marker on the chart.
  • high: Settings for the high marker on the chart.
  • low: Settings for the low marker on the chart.
object
styleSets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.object
marker Type Child Properties​
The following properties apply to the first, last, high, and low markers on the chart.
shapeShape of the marker used to indicate the first point. Options are circle, triangle, or square. Default is circle.value: string dropdown
sizeSize of the marker, in pixels.value: numeric
strokeSettings for the stroke for the first marker. Options as follows:
  • color: Color of the line. See Color Selector.
object
fillSettings for the fill for the first marker. Options as follows:
  • color: Fill color of the desired range. See Color Selector.
object
Component Events​
Example​
This example demonstrates what changes to the various marker properties can do. In addition, the desired range has been enabled.
PropertyValue
props.width1
props.dashArray6 2 2 2
props.desired.high60
props.desired.low25
props.desired.stroke.color#AAAAAA
props.desired.stroke.width3
props.desired.stroke.opacity3
props.desired.fill.color#CCFFF
props.desired.fill.opacity4
props.marker.first.shapecircle
props.marker.first.size10
props.marker.first.stroke.color#000000
props.marker.first.fill.color#00AC00
props.marker.last.shapetriangle
props.marker.last.size20
props.marker.last.stroke.color#000000
props.marker.last.fill.color#EF4D4D
props.marker.low.shapesquare
props.marker.low.size7
props.marker.low.stroke.color#000000
props.marker.low.fill.color#0D9D9
props.marker.high.shapesquare
props.marker.high.size7
props.marker.high.stroke.color#000000
props.marker.high.fill.color#FF47FF
props.style.backgroundColor#E2F1Fa
props.style.borderStyleoutset
props.style.borderWidth7px
props.style.borderColor#9BBFBF
