Common Scripting Tasks
This section contains examples for items we've identified as "common" tasks: undertakings that many users are looking to utilize when first starting out with a specific module or feature in Ignition. Additionally, this section aims to demystify some of the more complex or abstract tasks that our users may encounter.
The examples in this section are self-contained explanations that may touch upon many other areas of Ignition. While they are typically focused on a single goal or end result, they can easily be expanded or modified after the fact. In essence, they serve as a great starting point for users new to Ignition, as well as experienced users that need to get acquainted with a new or unfamiliar feature.
Below is a list of common tasks related to this section of the manual.
Reading and Writing to Tags​
There are simple interfaces in Ignition that allow you to easily write to a Tag on some Event, and Reading can be as simple as creating a Tag binding. Sometimes, however, the built-in approaches can be too simplistic or limiting. The Reading and Writing to Tags page details how to better interact with Tags from scripting.
Importing and Exporting a CSV​
CSV files are used by many software programs to export data so that other systems may utilize the information contained within. The Importing and Exporting a CSV page demonstrates how to both import a CSV into Ignition, as well as export data from Ignition into a CSV.
Reading a Cell from a Table​
Once data is populated into a Table component, it's useful to know how to read and extract a data from a cell in a Table, particularly if users can select a row in a Table. The Read a Cell from a Table page has some good examples for retrieving data from a single cell and multiple cells in a Table.
