Comments Panel Scripting Functions
This page details the various component and extension functions available for Vision's Comments Panel component.
Component Functions​
This component does not have component functions associated with it.
Extension Functions​
insertNote​
  • Description
    • Called when a note is added.
  • Parameters
    • component self - A reference to the component that is invoking this function
    • string note - The text contents of the note
    • string filename - The full filepath to the the attachment
    • string sticky - A boolean indicating whether this note should be flagged as stickied
  • Return
    • Nothing
  • Scope
    • Client
deleteNote​
  • Description
    • Called when a user clicks the 'delete' link on a note.
  • Parameters
    • integer id - The id of the note
  • Return
    • Nothing
  • Scope
    • Client
unstickNote​
  • Description
    • Called when a user clicks the 'unstick' link on a note.
  • Parameters
  • Return
    • Nothing
  • Scope
    • Client
downloadAttachment​
  • Description
    • Called when a user attempts to download an attachment from a note.
  • Parameters
  • Return
    • Nothing
  • Scope
    • Client
canDelete​
  • Description
    • Returns whether or not a note with the given id can be deleted. Notes that return True will show a 'delete' link.
  • Parameters
  • Return
    • boolean - Notes with a True return can be deleted by the user, False return can not be deleted.
  • Scope
    • Client
