Version: 8.1
system.math.sumDifference
Given two sequences of values, calculates the sum of each sequence and finds the difference between them. In other words, the difference between sums from two sets of numbers.
Throws a DimensionMismatchException if the two sequences have different lengths.
system.math.sumDifference(values1, values2)
List[Float]values1A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN.
List[Float]values2A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN.
Float - The sum difference, or NaN if one of the parameters was empty or null.
Example #1
# Create some lists.
firstList = [3.5, 5.6, 7.8, 7.4, 3.8]
secondList = [3.5, 5.6, -7.8, 7.4, -3.8]
# Print the resulting value.
print system.math.sumDifference(firstList, secondList)
