system.math.sum
Given a sequence of values, calculates the sum of all values. The sum is the number returned by addition.
Returns NaN (Not a Number) if passed an empty sequence.
system.math.sum(values)
Type | Parameter | Description |
List[Float] | values | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a Sequence of numerical values will return NaN. |
Float - The sum of all values in the values parameter, or NaN if values was empty or null.
Example #1 - Summing All Values In List
# Create a list of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Print the resulting value.
print system.math.sum(values)
