system.math.meanDifference
Descriptionβ
Given two sequences of values, calculates the mean of the signed difference between both sequences. In other words, returns the absolute difference between the mean values of two different sets of data.
Throws a DimensionMismatchException if the two sequences have different lengths.
Syntaxβ
system.math.meanDifference(values1, values2)
Parametersβ
| List[Float] | values1 | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. |
| List[Float] | values2 | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. |
Returnsβ
Float - The mean difference, or NaN if one of the parameters was empty or null.
Scopeβ
Code Examplesβ
Example #1 - Calculating Mean Difference
# Create some lists.
firstList = [3.5, 5.6, 7.8, 7.4, 3.8]
secondList = [3.5, 5.6, -7.8, 7.4, -3.8]
# Prints the resulting value.
print system.math.meanDifference(firstList, secondList)
