Version: 8.1
system.math.geometricMean
Calculates the geometric mean. Geometric mean is a type of average which indicates a value in a set of numbers by using the product of values in the set and then taking the nth root, where n is the number of values in the set. This is different than an arithmetic mean, which calculates an average based off the sum of the numbers, and divides it by n number of values. Geometric means can only be positive numbers.
Returns NaN (Not a Number) if passed an empty sequence.
system.math.geometricMean(values)
List[Float]valuesA sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN.
Float - The geometric mean, or NaN if the input was empty or null. Because this uses logs to compute the geometric mean, will return NaN if any entries are negative.
Example #1 - Calculating Geometric Mean
# Create a List of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Prints the resulting value.
print system.math.geometricMean(values)
